valhalla360 wrote:
If you go thru the state scales and are overweight, you get a ticket...typically a very expensive ticket and they may detain you until you can get another truck in to offload the excess weight.
Legal axle weights are generally 20,000 on a single axle, 34,000 on a tandem axle, and 80,000 lbs on 5 axles. Do you really think you exceed any of those weights? Seriously? All those 'big numbers' confuse people. Let's put this in perspective since people apparently have a real difficultly comprehending weights.
Look at that truck tractor semi trailer running down the road. Empty weight on that rig is going to be about 23,000 lbs.
Now look at that ton pickup with a 40 ft 5er for example. The pickup will weigh about 8000 lbs. The 5er loaded may weigh 14,000 lbs. Total weight, loaded, 22,000 lbs.
So you're loaded 5th weighs less than that empty semi truck you see on the road. That empty semi will weigh more on 1 axle than your entire ton pickup.
You think you're overloaded with E rated tires on your pickup and maybe G rated tires on your 5er? You're not even close. Your tires would never support the weight to be overweight.
Overweight? Let's be realistic folks. You're not even close.
I weighed trucks for a lot of years. I taught weight laws for a lot of years. The courts recognized my training and experience as an expert in weight laws.
You're not going to be overweight so quit worrying about it. You're not going to have to unload your wife's rock collection. No one is going to get a ticket. You're not going to jail.
