cs2kplus's avatar
cs2kplus
Weight and Truck
Have a 1989 Fleetwood Taurus travel trailer. Weight is 6500. Need to get a truck. Can someone tell me what the minimum I should be looking for. I read all about tongue weight, etc. I have in my driveway. Just bought. Was delivered. I have no way of bring to get weighed. Thanks!:S
  • Actually I had my eye on a 1990 7.3l v8 deisel. rear drive.
    Follow your own good advice.
  • Depending on the cab configuration, trim, and package Ford F150 1/2-tons can have a payload from 800# to 2200#.
    On the door jamb there's a yellow sticker that lists the payload for that particular truck. Ignore the manufacturers brochure payload weights, they're for stripped-down models.
  • @downtheroad: I was told that by someone. I don't understand how the tonnage related to the rv weight. Like they say 1/2 ton. That would be 1000 1bs. Is that where tongue weight comes in. I think that means the truck can carry 1000 1bs of dirt, etc?
    @seattle..:see above. Now your adding deisel. Actually I had my eye on a 1990 7.3l v8 deisel. rear drive.
    @mbopp: Lets say we won't travel light....thats for sure. Well...I try to...but that never happens. So I guess 1/2 ton (see above - cause it confuses me) is minimal...and seems like 3/4 is more idea. I am all for overkill....within reason. so 3/4 tone are 350/3500?
    One thing for sure...is in 1989 there was a good match for this rig. I am looking for something between 90-2000ish for like 5K max. I see plenty out there....just not sure what I should go with. Sounds like 3/4 at this point. Keep in mind...this will be used primarily for camping trips somewhat local only. May want to take a 10 hour (one way) trip in the fall.:)
  • Another question - How many people & how much gear are you hauling? Crew cab 1/2-tons run out of payload real quick with an S.O., 3 kids, a dog, and bikes / firewood in the bed.
  • cs2kplus wrote:
    Ok....answers for 3 comments:
    1. yes that is the dry weight. It is on the camper label.
    2. I agree....minimum is really a bad choice of words for me. Let me say I'd like the minimum x 1.5 or 2.
    3. Oh...did not know there was a section for towing. Good point.
    Thanks all. Any follows ups are appreciated.:B
    OK in that case, to answer #2 ...go at least 2500/250 for the truck, since you are starting with 6500 dry.
  • Ok....answers for 3 comments:
  • I'd post this in the tow vehicles section as you might get better answers.
  • You don't want to look for the MINIMUM! You want to look for the most truck you can afford, new or used. You will never (?) buy a smaller, lighter, trailer in the future and buying a little "extra" truck now saves a lot of grief then.
    //The question mark is to head off the one person who will jump in saying,"Oh yes; we bought a smaller trailer." Go away!//
  • Welcome to the Forum...
    You said you couldn't get it weighed.
    How do you know it weighs 6500? Is that the dry weight?
    Knowing the weight (GVWR - gross vehicle weight rating) of the trailer is the starting point for deciding what truck will work best.
