cs2kplus wrote:
@ol' grouch...I hear ya. But I don't have a way of weighing the camper at this point - without a truck to take it to a weigh station. As far as loaded weight? I would say it would perhaps be 2 adults and 3 teens max. That's what?....800 lbs right there. So 6500 + 800 = 7300. Added weight to rv? I can only give a high guess of 1000? So now we are at 8300. I looked at a f150 and the guy said its towing capacity is 8100. So that would tell me to step up to f250.
I get confused with the total weight vs. towing capacity. I understand the GCVWR is important to know. But I do not know how that relates to towing capacity. Man - I wish someone had an online calculator to input this stuff and get a real birds eye view of what is needed. As far as the truck brakes, engine, transmission being up to it? I do not know how to calculate this? This is in fact turning into rocket science.
Rear end gears and brakes are the two things that affect this the most. Your rear end ratio makes the biggest difference. My Ram 2500 for instance has 3.55 to 1 gearing.The bigger the first number the more mechanical advantage you have. I've seen folks run 4.11 to 1 which will pull a house down. It also makes the engine run faster to maintain a speed. What it means is the drive shaft turns 4.11 times for one ratation of the axle (and wheel). If I were to order a truck new, I'd get about a 3.7 to 3.9 to 1 ratio gearing. Gearing in the transmission helps when you use lower gears, like in traffic, but it only helps a little on the highway.
Oversized brakes are the other part of the setup. 4 wheel discs don't overheat as much as drums and you want trailer brakes on all the axles. If you think you'll use the truck a lot without the trailer and hit the hills with it, I'd recommend going with a 3/4 ton truck like the F250, and see if you can get a deisel. They cost more but have superior towing ability and much better fuel mileage under load. My Ram 2500 with the gas engine can stay with the oil burners, until we get to a fuel stop.
One thing to watch for on diesels, you DON'T want one that's been cranked up. A lot of guys do that to make them smoke and really pull. It also increases wear and shortens the service life of the vehicle. Ford makes a good diesel truck and the Dodge Ram with a Cummins is the puller of choice around the shops where I hang out. The Cummins puts out 1/3 of what it is able but that's so it will last several hundred thousand miles. Diesels are also pretty dainty on some things. Overheat one and you rebuild it. Change the oil and it is in gallons, not quarts. One fellow was talking today and mentioned it takes 3 1/2 gallons to change his oil. Dodge now has a smaller oil burner in the 1/2 ton. I don't know how it will handle pulling.
