noteven
Nov 23, 2015Explorer III
westend wrote:06Fargo wrote:Yeah, the biggest issue with a travel trailer is the dimension of the walls and ceiling cavity. There is just so much you can do with a 1 1/2" wall. I'm pretty happy with the result of my two weeks of insulation installation. I probably have about R-7 in the walls and R-15 in the ceiling. Since the space is small, it's easy to heat and stays cooler in the Summer.westend wrote:06Fargo wrote:Sure, but you would be losing a lot of interior room by expanding the dimensions of the wall, floor, and ceiling. Triple pane, argon filled widows are a solution to better window R-value but an insulated shutter does have some merit. Radiant heating is expensive to implement. If you wish to give up space for a heat exchanger, that would be a great idea.
Wouldn't a unit with all living and storage spaces, tanks, and systems totally enclosed within a R40 roof and R20 walls and floors envelope be nice? Drop down window insulators for cold nights or hot afternoons, low amp radiant heating, controlled heat recovery ventilation...
One thing nearly all RV's lack is a continuous vapor barrier. Also, installing a thermal break between framing and the interior walls afford a lot more comfortability.
I have some of the above in my trailer, it is easy to heat and is super quiet inside.
I am thinking closed cell foam at R7 per inch, including a thermal break between the structure and interior wall finish. So probably a 4 inch wall thickness and 6 inches roof. Radiant heat could be complicated "systems" or a couple or three marine direct vented heaters.
The unit might not be towable with a pick-em up truck OMG.
Hydronic heating is in my wish list. When I upgrade my solar, I plan to use the "load" function of the controller to power a 12V water heating element. It won't handle Winter in the oil patch but will help.
I'm thinking a custom build kind of idea. The walls would have to be as thick as needed - probably 3-1/2" with finishes. Totally insulated box with all systems contained inside the insulated envelope to control air infiltration, temperature, and humidity. The climate is controlled inside the International Space Station right? It should be possible in a RV too... on less than 50% of the budget...:B
About RV Newbies
