- rvshrinkerExplorer IIII keep trailer plugged in at all times when not traveling. I've checked water every six months for two years and have never needed to add water. We do live in a mild climate with rare freezing and rare temps over 90.
I remember now when I ordered the RV, on the advice of this board, I asked to be upgraded to 2 6v batteries. - opnspacesNavigator IIINo real implications, at least probably nothing you'll notice. They should give you a longer service life. But like all things in life that is entirely dependent on how well you maintain them. If you abuse them by letting them sit discharged, only partially charged, or let them run out of water, they won't be any better than 12 volt batteries.
If not abused they will last longer in an off shore power scenario. They will also survive more discharge/recharge cycles before needing replacement than a 12 volt battery.
As far as your trailer dolly, there is probably no real noticeable difference between 6 volt or 12 colt batteries. - bikendanExplorer
rvshrinker wrote:
Huh. Turns out i have 6v batteries. What are the implications of that vs 12v?
You're better equipped for dry camping or boondocking. - rvshrinkerExplorer IIIHuh. Turns out i have 6v batteries. What are the implications of that vs 12v?
By the way, dolly worked great! My RV is tucked neatly into its carport, hooked up to a large propane tank and home 30 amp RV service. I also dumped in my new sewer cleanout and cleaned the black tank using sani clean. - opnspacesNavigator IIIYes that is correct for 12 volt batteries.
time2roll wrote:
rvshrinker wrote:
The batteries will be wired for 12v either way. Connect same as the main RV power cables are connected and you are good to go.
i am attaching a parkit360 trailer dolly to my TT and the battery hookup differs depending on whether I have 6 or 12 volt batteries. i have two of them. how do I tell?
Picture just above shows perfectly what I am saying.
I'll get in there and look tomorrow but assuming two x 12v then pos to pos on one battery then neg to neg on other battery. Remove in reverse order? - wa8yxmExplorer IIIGood advice. If you are not sure if it's 6 or 12 based on the above.
Harbor Freight has some very nice 5.00 dollar volt meters. Learn how to use 'em. rvshrinker wrote:
Picture just above shows perfectly what I am saying.- Old-BiscuitExplorer IIITwo 6V batteries (Series) VS Two 12V batteries (Parallel)
6V wired in series....
POS on one connected to NEG of other battery
You would connect your Power Dolly cable to POS of one and NEG of other
12V wired in parallel.....
POS connected together and NEG connected together
You would connect your Power Dolly cable to a POS and NEG on just one of the batteries (Same Battery) - opnspacesNavigator IIIShort answer is 12 volts. Count the caps (in reality you want to count the cells under the caps). Each cell in the battery is 2 volts. But regardless of 6 or 12 volt batteries you're going to be hooking up to the batteries in a 12 volt configuration.
About RV Newbies
