Lantley
Dec 22, 2015Nomad
While you can get by without a toad. Traveling from CG to CG in a motorhome is easy . But sightseeing in a MH can be a hassle.
You will have to beware of every turn. Parking maybe available but not convenient. A simple 1-way street can cause havoc.
I often use my dually pick up truck to site see. In metro areas or high volume tourist areas my dually can be a headache a MH will only be worse.
Keep it convenient you will enjoy yourself more vs. having the burden of traveling in a huge vehicle. A MH was a designed to do a lot of things, however site seeing isn't one of them!
Think of it like getting gas. With a car any station will do however with a MH you will have to plan your fuel stops accordingly.
Consider all MH's have toads for convenience sake. Every MH you see could make an alternative plan to get around vs.a toad.
However in the end a toad is the easiest most convenient solution.
Why reinvent the wheel!
About RV Newbies
