GordonThree wrote:
Bucky Badger wrote:
GordonThree wrote:
Bucky Badger wrote:
shootnmiss09 wrote:
Hey guys,
I was just thinking, I know they have WiFi thermostats for your home that you can control from your smart phone. Do they have something like this for a camper 12 volt system? I think it would be nice to turn air or heat on before getting to the campground.
How would you run the ac?
Some RV have AC already on a wall mount... otherwise, you open your rooftop, disconnect the built-in thermostat from the fan and compressor relays, and connect those to the wall mount. Leave the AC's control knob turned on to either low or high and the wall thermostat (wifi or otherwise) controls it. There are videos on youtube, it's not as bad as it sounds actually.
Where will you get power from?
Haven't done the mod myself, not sure.
You'll want to consult the service manual for your rooftop unit and see if it's got any low voltage built in. Some I found seem to use 12vdc for the control relays, others are straight 120vac.
I think badger was referring to the power to run the A/C...the OP mentioned a 12v system.
