DutchmenSport wrote:
You don't want to put RV antifreeze (pink stuff) in your camper water heater. It's too time consuming and takes too much water to flush it out when you get ready to use it. If the tank is empty now, and you are not going to use it till weather gets warmer, leave it empty. Put the anode rod, or the plug back in. Hook it up and forget it.
Do I need to run the pink stuff thru my water lines? Or can I just empty them all as well and leave it all alone until spring?
Thanks for your response.
