JoshuaH wrote:
I was wondering, is there any reason why I can't use compressed air to blow out all the water in the lines? I have an air compressor, wouldn't be hard to make an adapter that will hook to the water connection.
Thanks!
No need to make an adapter there are two different versions of it already on sale at your local RV place even Wal*mart will have one
One has a "Stem" capped with a small rubber cap. This Stem though nto threaded is the same size as a tire valve stem.. The other one has a "Quick Connect" fitting (I forget which style) that matches the chuck on most personal air compressor hoses (Type M I think but do not quote).
And no there is no reason not to do it that way. IN FACT I did it that way before I switched to the "S" method (Drive South).
HOW I did it.
Drain and bypass water heater. Drain fresh tank. Open all valves including low point. Screw adapter in and set regulator on Compressor (I used a 6 gallon pancake 150 PSI job) to 50 PSI.
Let 'er blow. When it ran out of air go inside and force cycle the ice maker (Optional remove solenid to warm place). then shut off water valve to ice maker (Force cycling the water in the line will drain into the main lines in the rv) Open the intake strainer on the Water pump (Place towel below it to catch water) and drain it.. Run pump for like a minute then turn off and re-assemble trainer (Run pump DRY of course to clear it and it's outlet line)
LOOP By now the air compressor has recovered so BLOW again.. When it runs low stop blowing and have some coffee. ENd loop
I ran 5-10 cycles of the loop.. Eventually I ran out of coffee :).
Now I'm not getting any gurgle sounds. no more water out. Close valves Flush toilets. I had a home dump station so I dumped (you can do this at last campground) and added pink to toilets and sink trap and Flush toilet once more (Let some pink into the black tank) and re-pink it.. Head in to house for winter.. Returning daily to RV for Radio Nets (it's my ham shack after all) but not using plumbing save to sit on (Lid closed). (Like Guitarist Joe Walsh, not to be confused with the other Joe Walsh, My "Radio Room" has plumbing.. That way when you got to go somewhere you don't have to miss your turn on the net you are checked into since where you have to go is where you already are).
