ivbinconned's avatar
ivbinconned
Explorer II
Feb 21, 2019
09 Cedar Creek bed room tv won’t work??
I have checked all cables that run under fireplace/ tv slide. All is good there.
Main tv works fine. There are two wall connections behind bedroom tv. Right one has a sticker that says satellite. I have scanned on each. Nothing.
The bedroom has no booster switch like the one in living room.
I have tried booster on or off.
What am I missing?
  • That is what my next move will be. I have a cable to reach from trailer to pedistal. But it isn’t long enough to reach from rear wall (main tv) to bedroom.
    I’ll have to borrow one.
  • Try connecting it via a temporary overland connection to where your downstairs tv is connected. If it works then you likely have an issue with the wiring and will need to rewire it. As much as this sounds bad there's many options with the basement in a large fiver.
  • It turns on. I do a scan and it finds no channels.
    I don’t think it ever did work for me as we never were I terstedin watching it till lately.
  • 1. Does the bedroom tv work if you connect it to where the main tv is connected? If it doesn't the tv is the problem.
    2. If it does remove the wall plate and connect directly to the 2nd tv connection on the back. If it still works the problem is in the wiring to the bedroom. If it doesn't the problem is in the circuit board.
  • All connections behind wall plates look good. Tried different cable between wall and tv. Still nothing.
  • Has it worked previously or something that never worked? I would pull the wall plates and check that connection on the back side is good. Do this both in the bedroom and at the one with the booster switch.
  • The booster switch is for your OTA external antenna. Only one switch is required per antenna. Did you check the INPUT/Source setting in the bedroom tv menu?
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 21, 2025
