GlennLever's avatar
GlennLever
2 to 1 tail light conversion module
I currently have a MME 5 amp Powered tail light conversion module.
It worked fine until I put LED tail lights on the trailer.
Now the left and right turn signals work, the marker lights work, but the emergency flashers do not.
I currently have the conversion box attached to a terminal box that contains all the connections for the trailer plug on the Motor Home.
I need a GOOD quality conversion module that works with LED (low current draw)
I would like the same style, vehicle wires on one side and trailer wires on the other, well labeled and flat
  • GlennLever wrote:
    ChooChooMan74 wrote:
    Unfortunately, they must have changed it since I got mine (Notice in the description, it says "upgraded") Mine looks like this
    That is more what I am looking for. Manufacturer? Does it state it is good for LED lights?
    That is the old version of the link that I provided above. They changed the design. The old number is tow ready 119190 and the new one is 119191
  • Unfortunately, they must have changed it since I got mine (Notice in the description, it says "upgraded") Mine looks like this
    I use this from eTrailer. I used it in 2 vehicles that had amber turns. I installed this after installing LEDs in my first vehicle, that totally messed up everything with another converter in place (probably what you're going through). Then, when I got my 2nd vehicle, I put LEDs in it right away, and got this coverter again for the trailer. You can see my review on it, too, on etrailer.com (Matt M).
    http://www.etrailer.com/Wiring/Tow-Ready/119190KIT.html
    Wow, $74.00.
    I just need the module and would like the wires for the trailer and Motor Home split.
    Not in this configuration.
  • I use this from eTrailer. I used it in 2 vehicles that had amber turns. I installed this after installing LEDs in my first vehicle, that totally messed up everything with another converter in place (probably what you're going through). Then, when I got my 2nd vehicle, I put LEDs in it right away, and got this coverter again for the trailer. You can see my review on it, too, on etrailer.com (Matt M).
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
