Road Phantom wrote:
I noticed that some of the new model trailers are coming with 20 lb propane tanks like the ones they sell at Walmart and other retailers. I can see the convenience of that. Anyone change their tanks to accommodate them instead of the standard 30 pounders?
Our previous KZ Spree came with twin 30 lb tanks and I never gave it much thought, other than after filling I had to lift the stupid things into position on the trailer. :E Our current Freedom Express came with twin 20 lb tanks and I find them
much easier to lift into position. We camp from April to Nov and because I keep the trailer here at the house I use it often including the furnace yet find I usually only have to refill one of the 20 pounders once during the season. With 30 pounders I could avoid filling during the season entirely but on the weight argument alone I'd far rather stick with the 20 pounders I now have. :B
Regarding filling by weight I see the old wives tale about the "80% rule" still abounds ... BUT the reality is a "20 lb" propane tank
does contain 20 lbs of liquid propane gas when filled to 80% capacity. On the tank collar is the tank's WC (Water Capacity) rating ... multiply WC by .42 and you'll have the tank's propane capacity as measured in pounds. For example, one of my 20 lb tanks has a WC of 47.6 ... multiply times .42 and we have 19.992 lbs. Also on the tank's collar is it's tare weight (TW) or empty weight ... mine is 18 lbs so when that tank has been properly filled to 80% capacity with 20 lbs of liquid propane gas it should weigh 20 + 18 = 38 lbs. I had this tank filled just last week and indeed it weighed right around 38 lbs. Here are details on
filling by weight, including a simple cylinder filling chart.
