Bobbo
Nov 19, 2019Explorer III
For testing purposes, plug in using a 30 amp to 50 amp adapter. That puts voltage on both legs, but it is the same phase so there is zero voltage between the two hot wires.
Now, you can look for wherever there is no current/reduced current/low voltage without risking damage to anything plugged in from 240v. A loose neutral under those conditions will just look like an open circuit or loose connection.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
