Wayne_Preston's avatar
Mar 21, 2018
2006 Honda Element
I have a 2006 Honda Element with Auto Transmission and All Wheel Drive. Is anyone towing one of these. Honda says no, but I have heard that you can do it with all 4 down.
  • Thanks for the answers! I feel a lot better about towing it now. I will order my tow bar today. Thanks
    My guess is the Honda people know about their vehicle than the people on the internet. How lucky are you? If Honda is right, no charge to you. If the internet posters are wrong, you will have a gigantic repair bill. How lucky are you?
  • With my CRV which I think has the same running gear as the Element, as said above, run the engine for a few minutes and put it through the gears but always go to Neutral from Drive not Reverse to Neutral before shutting off. My manual says to change trans fluid every two years if towing as well.
  • Yes you can. Same tranny as a CRV.
    I tow a 2011 Element.
    You just need to follow “The Procedure”.
    Idling with foot on brake slowly shift from P R N D 2 L 2 D N then idle for at least two minutes.
    I repeat at lunch.
    Also Honda says to change trans fluid every 30K?
    Check that. Maybe 20K.
    10k sooner than dual.
