From RAM TSB 14-007-06 dated August 25, 2006 :
"Models: 2006 - 2007 (DH/Dl/DC) Ram Truck (Heavy Duty)
NOTE: This bulletin applies to vehicles equipped with a 5.9L High Output or a 6.7L Cummins Turbo-Diesel Engine (sales codes ETH or ETJ respectively) that were built on or after March 07, 2006 (MDH 0307XX)."
"- A maximum blend of 5% biodiesel (B5) is acceptable as long as the biodiesel mixture meets ASTM specification D-975, D-975 - grade S-15, and ASTM D6751. A biodiesel fuel blend that is higher than 5% is not acceptable without additional fuel processing because these higher percentage biodiesel blends contain excess amounts of moisture which exceed the water stripping capability of the on-engine final fuel filter. Should a higher percentage biodiesel fuels be used an auxiliary water stripping filter will be required.
- A maximum blend of 20% biodiesel (B20) can be used by government, military, and commercial fleets who equip their vehicle(s) with an optional water separator, and adhere to the guidelines in the Department of Defense specification A-A-59693 (in addition to: ASTM specification D-975, D-975 - grade S-15 and ASTM D6751)
So in short, they feel you need a better water separator.
