blt2ski
Jan 13, 2015Moderator
If you stay in the under 1000' elevation range, ie mostly in FL, you should generally speaking do fine to about 5K maybe 6K with that motor. BUT
The chassis is probably capable of upwards of 7-8K lbs handling. Your engine and lack of hp will be your biggest issue. I am also assuming you have a 4 sp auto?!?!?! not the more recent 6 sp. If you have teh 6 sp, your 3.42s are better off than a 4.10 geared rig with the 4l60 trans! so not a real problem.
There was a day, when you 4.3 was a typical BB monster motor in the specs it has! ie in 81, the GM 454 was 195hp and around 330 lb ft of torque! with a much worst trans option too!
Marty
Marty
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
