- wintersunExplorer IIThe stiffer the truck frame the less need their is for an anti-sway bar. These bars originated with ultra light weight sports cars. A side effect is that when one wheel hits a bump the force is transferred to the opposite wheel. With my truck when there is no load in the bed the bed this is a positive attribute as it softens the ride. Zero difference in handling with the Big Wig when there is a 3400 lb. camper in the bed or I am towing a heavy trailer.
- chryslermastertExplorerthye list them for 2014 2015 2500
- chryslermastertExplorerBAR,Rear Sway 05290355AA part number for rear sway bar for 2004 2500 model year in 2004 model year out 2006
i work as chrysler tech/parts person
5300 Part Inquiry
(00540)CALL VINTAGE PARTS AT 1-877-846-8243 TO ORDER. NO LONGER SUPPLIED BY MOPAR.
but there are dealers that have them in stock
no sway bar for 2011 - AH64IDExplorer
john&bet wrote:
ScottG wrote:
If that is the case then please explain why my '04.5 has one.
That went away with the 03 updated body. Dodge said the SB wasn't needed because of the increased length and geometry of the new trucks rear springs.
Because it's aftermarket.
There wasn't an OEM anti swaybar in 2004.5. - john_betExplorer II
That went away with the 03 updated body. Dodge said the SB wasn't needed because of the increased length and geometry of the new trucks rear springs. - ScottGNomad
AH64ID wrote:
ScottG wrote:
Excellent info - I think I'll put one on for the upcoming season camping.
You won't be disappointed.
I added mine because I was feeling the trailer (1200-1300lbs TW) on slow speed off-camber corners, on winding forest service roads. After the install that feeling went away.
Now I haul 2 quads above the bed rail, with gas/water/wood/etc below the bed rails and still have the same TW. Rock solid on corners and I only use about 20-25psi in the airbags.
Thanks, I've been waffling on this for years and wondering if it would really do any good when towing. - AH64IDExplorer
Now I haul 2 quads above the bed rail, with gas/water/wood/etc below the bed rails and still have the same TW. Rock solid on corners and I only use about 20-25psi in the airbags. - rhagfoExplorer IIIYour 2002 2500 was equipped with the Camper Package. 3500 springs and a sway bar.
- ScottGNomad
AH64ID wrote:
Exactly, a wider and longer spring and a stiffer frame made the bean counters think it wasn't needed.
I added a hellwig rear anti-sway bar to my 2005, which is the same suspension as your 2102 (I have upper overloads, but they are never engaged), and it has been an improvement empty and loaded. I have yet to find a situation where I don't like the swaybar.
While the truck was very stable without one, it's on rails with it.
Excellent info - I think I'll put one on for the upcoming season camping. - AH64IDExplorer
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
