az99
Jul 11, 2015Explorer
I tow a 2014 Focus. The battery disconnect is grossly blown out of proportion on this and other forums. I flipped the battery around in the case by installing a longer positive cable. It takes all of 10 seconds to remove or reinstall the negative cable at the battery. It takes less than 2 minutes to reset the time, date etc. on the radio.
You simply put it in Neutral, the display says "READY", disconnect the battery and tow.
It is a great car to tow and drive when you get there.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
