carringb
Jul 24, 2015Explorer
The only issue is making sure it verifies Neutral before shutting it off. Nearly all problems with towing this transmission have been due to shutting it off too soon. The newer versions already have the indicator on the dash to let you know. Older versions can be "re-flashed" at the dealer to add this feature, or as mentioned failing to disconnect power.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
