loydt
Sep 19, 2014Explorer
2014 Jeep Cherokee Question
This would be for any (or all I guess) with the push button start. When you go through the procedure in the manual for shifting to neutral, how do you shut the engine back off?
After you press the little "neutral" button and the light comes on, you are supposed to shift to neutral, start the vehicle, and then shift into drive and then reverse to ensure that there is no movement. After you confirm, when you try to shut it off it says "vehicle not in park". Well, you cant put it in park now because the engine is running and you will get some nasty gear clash.
This is the same procedure for my '12 Ram, but it actually has a key fob so you can shut engine off when not in park.
