lawrosa
May 15, 2017Explorer
gac914 wrote:
Okay, people had asked me to post results after towing. We had a "shakedown" run to a campsite, and towed to a State Park about 170 miles round trip. It towed like a boss! Although the V6 was, as suggested by some, not an out-and-out powerhouse, it did pull just fine. Transmission temps were only up about 2 to 4 degrees above usual, engine temp stayed stable, and I even saw some "V4" mode on level pulls. Got between 10 and 13 MPG, depending on the routing I took and how many stop lights I had to accelerate from. Everything went pretty well.
I do have a question for those out there more used to distributing hitches. I found I had to pull up another notch on the chain to get the truck level and a little more weight on my steer axle. Everything, truck and trailer, ended up about perfectly level, (far and away more than a lot of rigs I noticed coming in to the park!!!,) but my torsion bars are past parallel to the frame on the trailer (end of the bar where the chain attaches at the mini u-bolt is about 2 1/2 inches from the trailer frame). Will this hurt in the long run, or am I okay to leave as is?? Next trip out will be a long one from Illinois to Mount Rushmore in South Dakota!
You need to tilt the head more with washers.. Then you can use same link and bars may be parellel.
You can use up to 8 washers
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
