MFL
May 16, 2017Nomad II
gac914 wrote:
Okay, people had asked me to post results after towing. We had a "shakedown" run to a campsite, and towed to a State Park about 170 miles round trip. It towed like a boss! Although the V6 was, as suggested by some, not an out-and-out powerhouse, it did pull just fine. Transmission temps were only up about 2 to 4 degrees above usual, engine temp stayed stable, and I even saw some "V4" mode on level pulls. Got between 10 and 13 MPG, depending on the routing I took and how many stop lights I had to accelerate from. Everything went pretty well.
I do have a question for those out there more used to distributing hitches. I found I had to pull up another notch on the chain to get the truck level and a little more weight on my steer axle. Everything, truck and trailer, ended up about perfectly level, (far and away more than a lot of rigs I noticed coming in to the park!!!,) but my torsion bars are past parallel to the frame on the trailer (end of the bar where the chain attaches at the mini u-bolt is about 2 1/2 inches from the trailer frame). Will this hurt in the long run, or am I okay to leave as is?? Next trip out will be a long one from Illinois to Mount Rushmore in South Dakota!
Thanks for posting an update on your towing results! I figured it would work for you. Steep long grades can be a challenge for any gas engine. You will encounter some of this between Rapid City and Mount Rushmore, and other areas of the Black Hills. Most have a slow lane, if you still have your trailer connected, just watch temps.
Have a great trip!
Jerry
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
