portscanner's avatar
portscanner
2014 Wrangler Requires battery disconnect - What do you use?
We are 95% sure we are going to go buy a new 2 door Wrangler soon and I was doing some research. I downloaded the owners manual from the Jeep Web site and found in the instructions for "Shifting Into NEUTRAL (N)":
15. Disconnect the negative battery cable, and secure it away from the negative battery post.
Our Jeep Liberty does not need a battery disconnect, so this caught me by surprise.
I am curious what other Jeep owners are using for a disconnect. Pulling the cable of the battery and leaving it hang seems a bit crude. I see there are various disconnects on the market. Or is there a work around for this?
  • We just traded my wife's 2009 two door wrangler for a 2014 four door wrangler and had the same concerns. This is not the case. The 2014 doesn't have a steering lock so leaving the keys in the ignition is not required. We just back from our first trip with the new toad with no issues at all.
  • Interesting...very interesting.
    Incorrect information in the owners manual? Say it aint so!!!!
    10. Turn the engine OFF and leave the ignition switch in the unlocked ACC position.
    This is from page 552 of the 2014 owners manual from the jeep.com web site (see the link in my first post)
    It appears that the world has not come to an end by leaving the battery connected and the ignition switch off!
  • I do not disconnect the battery in my new Jeep. I need power for my brake system. 3700 miles so far and no problems whatsoever.
  • We have 2013 Jeep Wrangler. I never disconnect the battery, why. The car is not turned on when towing. I take the key out and put it in the console when towing. No steering wheel lock. This is one of the big advantages of towing a Jeep. Fast and easy.
  • There is no steering lock on a Wrangler column. So no need to leave the ignition in ACC. Why would you disconnect the battery? The owners manual certainly does't require that...
  • We've towed thousands of miles without disconnecting. Can't see any reason for it, the key is not on- there is no steering lock.
    Probably just out of date info in the manual.
  • you can buy a lever type battery disconnect at any automotive store. Once installed you only have to lift the lever to disconnect the battery when needed. Installation is very simple and most automotive stores will do it for you, free of charge.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
