FIRE_UP
Nov 27, 2016Explorer
CarolynandBob wrote:
Never mind about the base plate. I went with this one. Currie Enterprises CE-9033JK Enterprises Tow Bar Mounting Plate for 07-17 Jeep
If anyone know about the harness would be great.
The one that many of us Jeepers have used is the Hopkins part number 56200. There's no "powering up" of any pins or anything like that. It's a simple plug and play unit. It's all done at the rear and, all you do then is, run the four wires through the frame, all the way up to the front of the jeep where you then tie them into the female plug for the umbilical from the coach. Done!
Scott
https://www.amazon.com/Hopkins-56200-Simple-Vehicle-Wiring/dp/B009SIO9ZW/ref=sr_1_1?ie=UTF8&qid=1480309489&sr=8-1&keywords=Hopkins+56200
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
