KD4UPL
May 20, 2019Explorer II
I think your mileage is on the low side for sure. I think the mileage you report from the Tahoe is on the high side. Is this actual calculated mileage or are you using the built in vehicle display?
I question your driving style first. You say you are shifting it yourself and not using cruise. I would think that putting the transmission in tow/haul and letting it shift itself might give you a bit better mileage. Also, I would think using cruise would improve it a bit too.
When I tow I general engage tow/haul and set the cruise. I let the vehicle figure it out.
As mentioned, make sure your tires are rated for that speed. If they are ST they probably aren't.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
