Njmurvin
Jul 02, 2020Explorer II
I'm in the same boat. I'm planning to buy a 2020 GM truck with the OEM tow pucks.
For a traditional Superglide (I have the same), you need the adapter for the pucks to an ISR rail set. Then, you need an adapter (4409) to make your traditional hitch fit into the ISR rails. I spoke to customer service at Pullrite. The guy said it will work and be safe but there probably will be some slop (my word, not his). He also said it will raise the hitch an inch or two (wouldn't be more precise than that) in a truck bed that's already super high. The puck to ISR adapter is available from Pullrite. But, Demco makes one also and I kind of like the looks of that one better (less assembly to mess with).
I agree that they need to release the direct mount hitch. But, that doesn't appear to be imminent.
I'm intrigued by the new position of the mounts and possibility of using a fixed hitch. My 5th wheel is pretty square across the front so I need all the space I can get. Would a gooseneck setup get me any more distance between cab and trailer?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
