Scott64's avatar
Scott64
2024 190RBSLE Table Cushion Arrangement
We have this camper and cannot for the life of me, figure out the arrangement of the seat/back cushions when the table is down and used for extra sleeping.
Any suggestions or diagrams would be greatly appreciated.
  • I think what  you are describing is similar to what my neighbor has with two curved cushions. If your is similar you
    1. Remove the pole and lower the table down to make a flat bed.
    2. take the middle back cushion and place it on the table.
    3. Take the two curved side cushions and set them out of the way. They are not used.
    That's pretty much it.
  • You should probably not attempt to tow or operate the RV if this is an actual question….
    • Scott64's avatar
      Scott64
      Thanks for the help Grit Dog. It's weird though that in the 20 years we have been towing travel trailers, we have never ran into this issue. But I guess, according to you, we should not camp anymore. I appreciate your input!
    • StirCrazy's avatar
      StirCrazy
      Moderator
      some are hard to figure out, some engineer thinks "if we make them like this and you put those ones threre that one over here stand this one up on end, it will fit."
  • Could there be other cushions in the RV that you are supposed to use to fill the missing gaps?
    • Scott64's avatar
      Scott64
      No. The only cushions are in the dining area. 2 thick curved ones for the corners and the rest flat that should make the sleeping area.
        StirCrazy
        Moderator
        can you take a picture of the area made up for sitting at the table but with the table down in the bed position, it might be easier to see if we can actually see it.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
