BenK
Apr 28, 2015Explorer
Yes, the recommended rim width (bead to bead) is important, but many mount them
on the OEM 6.5" rim. There is an OEM 7" rim, but not all have that...most common
is the 6.5" rim width
Bead to Bead is the measurement on the 'inside' of the rim...unscrupulous marketing
uses the 'outside' measurement to make it 'seem' wider than it is
That narrower rim width creats more sidewall bendback and that increases the
potential ride quality...but reduces the tire's response characteristics
Of more concern is that the wheel's weight rating vs the new tires higher weight
rating
The wheel spec should be on the wheel somewhere. Suggest the OP check before
purchasing the higher rated tires
This is a picture of my Suburban, which has LT265/75R16E's on 16x10
alloys rated for 3.2K.
mysub mysuburban
rating
mysub mysuburbanAbout RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
