hayesdt's avatar
hayesdt
3.55 or Other Gear Ratio for F150
I have towed my Springdale 28 ft travel trailer (around 7000# loaded) for the past ten years with a 2004 Ram 1500 Quad Cab 4WD with a 3.92 axle ratio (tow rating was 8700# for the truck as equipped in 2004). Also, I always use Tow/Haul when towing and actually only tow the trailer about 3-4 times per year for a grand total of under 2500 towing miles annually. Never had any problem towing my trailer with the truck -- seems well matched. But at nearly 12 years of age, and though the truck has only 57,000 miles on it, I'm just no longer confident with it -- too many MAJOR expenses the past 2-3 years. So I'm looking at selling/trading the Ram and buying probably an F150 5.0L V8 Supercab Std Bed 4WD.
Just wondering, though, as I'm assuming a 3.31 gear ratio (9100# tow rating) would not be as desirable for towing the kind of weight I'll be pulling, whether I can get by easily with the 3.55 gear ratio (9200# tow rating) with the new F150 as opposed to the 3.73 gears (11000# tow rating). Would I really need the 3.73s?
Are any of you with the new 2015 (or even the 2014) F150's 5.0L V8 Supercab towing the approximate weight and size trailer I would be towing with the 3.55s rather than the 3.73s. Have you and your tow vehicle experienced good towing with the 3.55s?
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
