puma_28db's avatar
puma_28db
3.21 vs 3.55
Ram has built a number of 1500s, 5.7 hemi's with the new 8spd trans. Some or most of them have the 3.21 gears. The tow rating is about 2,000lbs less than the same truck with 3.55s regardless if the truck has the 6 or 8 speed.
1. Would the 8spd have more/better lower gear ratios than the 6speed?
2. With the trucks frame and engine the same, is the only facter changing tow rating the axel ratio?
3. Would towing the extra 2,000lbs with the 8spd/3.21 combo adversly affect the trans?
4. Yes tow/haul would still be used. does the 2 extra gears in the 8spd make up for the 3.21s in the rearend?
8spd with 3.21. 6speed with 3.55
1st. 4.71 vs 3
2nd. 3.14 vs 1.67
3rd. 2.1 vs 1.5
4th. 1.67 vs 1
5th. 1.29 vs .75
6th. 1 vs .67
7th. .84
8th. .67
5. Would the 8speed be suited to pull better with the lower gear ratios?
