MitchF150
May 23, 2014Nomad
Not getting fuel if it runs on the ether... 1998 should be EFI...
EFI would have an electric fuel pump in the tank.. Lay under the gas tank and have some switch on the ignition and you should hear the pump run for a few seconds.
You might try cranking it with the pedal floored.. Yes, I know you normally don't have to do this with EFI, but it's something to just try??
Good luck!
Mitch
Good luck!
Mitch
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
