Nick-B
May 23, 2014Explorer
Actually, Mitch has a good suggestion. On an EFI system, if you hold the pedal to the floor while cranking, the computer will NOT energize the fuel injectors. That way if it is flooding it will clear out and start. If that doesn't help then it sounds like you are not getting enough fuel pressure in which case it is likely a weak fuel pump. Common problem with the EFI 460 chassis.
BTW - while your coach is a 1998, the Ford chassis would be a 1997. There were no 1998 Ford F53 chassis made.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
