- 2oldmanExplorer IIYou don't have to come here, for that.
- RoyBExplorer IIII always liked this drawing from google search of a typical camp ground service pedestal...
Then when you get done with the wiring do the following test using a AC VOLTMETER before plugging in your trailer 50AMP Shore Power Cable.
If you can't duplicate these AC VOLTS readings DO NOT plug your 50AMP Shore Power cable into the receptacle.
Roy Ken - Crazy_RayExplorerI sure did screw my link
- BobboExplorer IIIGoogle is your friend. Use AT LEAST 6g wire for L1 (Hot1), L2 (Hot2) and NEUTRAL, and AT LEAST 10g for GROUND.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
