bama5er's avatar
bama5er
50 amp wiring
I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate generators. I have a "Y" cable adaptor for the purpose of using 2 power outlets (30 amp & 20 amp). If I run 2 separate generator sources they would be out of phase but would that be an issue considering the two 120 volt legs would remain separate. The only thing the 2 legs would have in common would be the common wire and the ground wire. Would the out of phase generators see each others phase and/or would it effect them in any way? I have 2 Honda 2000 generators that could power 1 leg. I would like to buy 2 more to power the other leg. I'm just wanting make sure this won't be an issue.
Thanks for your expert advice.
