atreis
Oct 17, 2017Explorer
demiles wrote:
In the SAE j2807 standard they set the distance from the pin hole to the ball center to 15.88 inches for WD 12k or less and 11.88 inches for WD above 12k. The max trailer tow rating with 10% hitch weight is set using these distances so there is a “standard” or recommendation per say.
FWIW - 40 cm and 30 cm respectively. (These things would be so much easier if we would just switch ...)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
