Just got my new Reese 5th Airborne out of the box. Under the hitch where the airline goes up into the bag are two bolts. They are sticking out about an inch. Is that right?
If your unit has 2 bolts on top of the unit and then the 2 under the unit: the bottom 2 bolts are used as guide pins and to not tighten to the body of the unit.
Thank you for contacting the Technical Group.
So I guess on mine they are supposed to be loose. I should specify to you guys that my hitch is the 16k model 5AB-E1621-16K
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
