- LynnmorExplorer II
speediq99 wrote:
I am running Goodyear Wranglers Territory AT OEM tires. Max load 2756 lbs. Max pressure 51psi. Load Range Standard load.
I have been running with 50 psi on the tires while towing.
MC
I believe those are actually extra load passenger car tires. - Cummins12V98Explorer III
MC
I do believe you about the bouncing!!! Those tires are SOFT!!! - speediq99Explorer IIIt makes sense.
Hitch is pretty straight forward. I have worked with Equilizer manufacturer to adjust it. It is a 4 way 10k hitch with more than plenty capacity to spare for my load.
Trailer is brand new and lightly loaded, traveling with empty tanks, no food most times and light gear. The only thing I can think of is the trailer does not have torsion axles.
MC - TerryallanExplorer II
MC
In that case. That is all the tire you will ever need for that truck. In fact is is way more tire than you will ever need. If you are bouncing with those tires, it is more likely in the hitch, or trailer.
Think about it. You have over 11,000lb worth of tires on a truck that has a GVWR more than likely less than 7,350lb. Unless you have the HD F150.
were I you. I would look elsewhere for your problem. - speediq99Explorer III am running Goodyear Wranglers Territory AT OEM tires. Max load 2756 lbs. Max pressure 51psi. Load Range Standard load.
MC - mkirschNomad II
noteven wrote:
I walked by 5 units here at the rancho - all have "Load Range E" marked on the tires.
4 different weight capacities depending on the tire size and load index. 3640lbs down to 2680lbs.
Us know-it-alls might understand what "10ply" slang means - same as "3/4 ton" vs 1 ton - but maybe we shouldn't be sending someone new to the sport looking for "10 ply tires"...
Tire guy shows him "10 ply" tires. Marked on tire is "Sidwall 2 plies polyester..." - newbie customer looks confused....
It's not slang. The tires SAY "10 ply rated" right on them. - JIMNLINExplorer III
speediq99 wrote:
Towing a 7000lbs tt with F150 2021 w/ 6 ply factory tires. Experiencing some bouncing.
Would I see a difference with 10ply tires?would the ride w/o a trailer be too stiff?
Thank you
MC
I'll repost the OP question about a 1/2 ton truck/10 ply rated tires as sound like some of the replies has to do 3/4 or bigger trucks.
The OP still isn't clear if he has LT C or a P tire on his truck or what psi is he using in them especially the trucks rear tires. - LantleyNomadOnce upon a time I had a F250 work truck that I bought used with c or D rated tires on it (Can't Remember) Long story short I kept getting flats on thes truck. Especially if a had my dump trailer connected.
I finally figured out I needed to get rid of the soft tires it came with and buy a set of E rated tires that I always use on my trucks.
At first I was reluctant to get rid of the original tires because they were very new with lots of tread. But after a few flats I figured out the soft tires were not up to the task. Stiffer tires can make a huge difference.
Changed to E rated tires no more flats. - philhExplorer III
speediq99 wrote:
Phil
What tires did you go with for your truck?
I never thought the trailer tires had that much influence but I will look into it. I don't experience sway but I do experience bouncing in the truck.
MC
Michelin Defender LTX. I was SHOCKED at the towing difference. In my size, they came as "D" or "E", I went with "E". - Grit_dogNavigator II
Terryallan wrote:
Usually the factory tires are only rated to 2175lb, at 44PSI. going to a tire rated 2601lb to 2760lb at 51PSI would be the thing to do. And no the ride with out the trailer would be just about the same as the 2175lb tires. You would just need to lower the tire psi to around 40psi with out the trailer. and of course air them to max psi, 51psi while towing.
"Usually" is not totally accurate, IMO. Plenty of half tons that come with greater than 44psi rated tires and 2175lbs isn't a magic number as there are many different load ratings in that range depending on tire size. My last 2 half tons had heavier OEM tires. Plus aside from new vehicles, the tires on it are whatever the last person installed.
Any upgrade is an upgrade, as you mentioned going to what is commonly referred to as XL rated tires.
That said, going to a full LT tire with a load index of 121 or greater has alot more benefits than drawbacks. Actually there's zero drawbacks, save for initial cost, which is generally more than offset by treadlife.
Advantages of a "LT" or "D / E" rated tire on a 1/2 ton.
Treadlife: Comparable brand and models often have greater tread depth than the P/XL versions. And often made with a more durable compound (essentially harder rubber, which can = slightly less traction in very poor conditions, but not if aired down properly for those conditions).
Handling: Stiffer sidewalls will give less, even at comparable pressures, making the vehicle handle a bit better. But not at the expense of ride comfort as that is primarily a function of pressure.
Stiffer sidewalls and harder compounds will further reduce wear of outside treads due to scrubbing in corners.
Durability: Thicker carcass = less prone to punctures.
And of course load capability: Most all D or E range tires are overkill for capability and provide a much improved factor of safety over tires that are "just enough."
Really a best value/no brainer thing for half tons. Not "necessary" in alot of conditions, but also not alot more money generally either.
Looking for advice before your next adventure? Look no further.25,175 PostsLatest Activity: Nov 09, 2025
