Yak
May 30, 2014Explorer
jllaco wrote:
It's a single tank. From what I have found, it's a single function fuel reservoir for times when the engine needs additional fuel, such as passing
I'm a Ford tech but it's been a long time since I've worked on these, the dual tank units have added outlets. I do recall these having filters in them. There's no way these would be used as you say, there's just a few ounces in them. Passing conditions use the vacuum fuel pressure regulator, 30lbs at idle or cruise, dump the throttle, lose the vacuum, fuel pressure goes up to 40+ lbs. Your issue right now could be bad orings inside the lines along with the lack of proper clips or the wrong size tube connecting the lines.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
