Padlin's avatar
Padlin
Accumulator sizing
Just picked up a new trailer and am in the market for an accumulator tank. In my old trailer I have a Home Depot 2 Gallon job that works great for cutting run frequency and takes care of all the surging. Unfortunately I don't have room for the bigger one in new trailer and can only find a 1 liter and something call a micro accumulator that doesn't tell you how big it is. Has anyone found a middle ground and if so what is it and where'd you get it?
  • Thanks for the link, went with the 1/2 gallon one that they sell.
  • the same one worked for us for many years since that is the only one we had room for.
  • Hi,
    I installed a 1 quart Shur Flow accumulator in my RV just after buying it in 1997. I was really happy with it, and later installed a 2 gallon one to make the pump really quiet. Both worked equally well.
    Fred.
  • Unless one is doing something very high volume, the ShurFlo is going to be the best solution to this. That, or tossing the water pump and getting a variable speed model.
  • Ron3rd wrote:
    Surflo makes a couple different small accumulator tanks that might work for you:
    Surflo tank
    I have the one in the link and notice a big difference in the smoothness of water flow. Had big pulsating water issues before installation. Had thought about installing a 2nd small one due to not having a good space for 1 larger one. Randu
  • No but we have the smaller Shurflo tank and it doesn't do much for us. Can't even tell sometimes if it is doing anything but taking up space in the pipeline. I also would like to find a mid size.
Looking for advice before your next adventure? Look no further.25,183 PostsLatest Activity: Jan 24, 2026
