lawrosa's avatar
lawrosa
Actual Payload of vehicles....
This thread was closed but I would like to put get some knowledge of actuals that may be of opinion or hard facts.
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/28525924.cfm
Im logical and am not the smartest tool in the shed, but I have a big shed....LOL..
I will use my 1996 s10 rpo ZR2 as an example. Check these #'s to see where I am going with this in relation to the link above..
My truck per door tag
GVW 4900 lbs
Axle ratings 2700
Now facts about what I have.
GM 8.5" 10 bolt rear. This is a 3750 lb rear per GM. 3.73
Tires 31" LT 2270 lbs per tire @ 50 psi.. = 4540 lbs
My weakest link is my axles I assume.
My trucks rear from scales weighs in at 1800 lbs.
With that said 3750 lbs axles - 1800 lbs scale weight gives me a 1950 lbs payload.
So if I beef up my spring pack to reflect 1950 lbs, I assume this truck can handle that weight per facts and #'s. ( I am now assuming my leafs may be the weakest link)
How about some super springs?
Super springs
Just like the poster in the link above where others stated his axles can handle it but his tires were the weakest link.( And if he changed his tires,) That some saw no issue except maybe his COG..
Theoretically with out talking about my v6 engine that probably could not haul that weight without burning up, the #'s state at a suspension stand point my payload is 1950 lbs..
And at present time I tow that 4000 lb trailer in sig ( wet) with a 420 tongue. ( 340 with WD) Scale weight 2200 lbs on rear. Leaves me 500 lbs before I go over my door tag rating of 2700 lbs..
And I can tell you I would not want to tow anything heavier..
So what you all think? Am I missing something?
  • GVWR - Actual Weight = Payload
    AND
    You must also be under you FAWR/RAWR also.
  • Sadly the biggest thing you missed is the smallest thing on your vehicle. That is the sticker on the drivers door post. There is nothing you can do to alter that. Secondly is cost! Upgrades, or rather add ons can become very expensive and add exactly zero to the vehicles value, and some can actually reduce a vehicles value.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
