AH64ID
Mar 24, 2014Explorer
wgriswold wrote:
The manual says that lowering the bracket one hole down is the same as removing one washer. So adding one washer while moving the bracket one hole down will deep the same weight distribution.
Exactly.
My bars are 1 hole out of parallel with 6 washer. I have 2 more sitting on the shelf, but with the current angle of the ball it can be difficult to close the latch so I don't want to add a 7th.
The other thing I did, to get a little more bar tension and level the load, it add a 1" taller ball. It did quite a bit for tension on the bars as the bars don't move but the L brackets came up a little.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
