Ron3rd
Mar 24, 2014Explorer III
uintafly wrote:Ron3rd wrote:
If your bars are not parallel, I doubt adding a washer will do anything. All that does is puts more tension on the bars and transfers more weight to the front, it does not change the angle of the bars. Check the manual first, it sounds like it's not set up right and you need to move the head up or down or the L-brackets on the trailer up or down.
You are correct. I probably didn't explain myself well. I am moving the brackets to make the bars parallel, but and I have a feeling that will not provide enough distribution, which will cause me to change the head angle to create the same distribution.
Sounds like you're on the right track. Get the setup level first and then add tension by adding washers.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
