wgriswold
Mar 24, 2014Explorer
uintafly wrote:
Yep, I think I will be fine with that. But the manual is a little fuzzy on how much if any to adjust the angle bolt. Has anyone adjusted one before?
IIRC the angle bolt just snugs up against the washers and there is no further adjustment.
I called the factory and was told that the bars do not need to be parallel to the trailer frame. In a sharp turn I would make sure that the end of he bar does not contact the trailer if the bar is not parallel.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
