uintafly
Mar 26, 2014Explorer
I ended up taking care of everything last night. Had to add 2 washers and drop 2 holes. I also was running almost 2 inches tongue high, so I also dropped down an inch on the shank. Now I am running a little tongue low, which is fine by me. I was able to get the bars parallel and return the front wheels to the same height as before. Once you read through the manual the Equalizer is surprisingly easy to make adjustments on. Thanks again for the help.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
