Ron3rd
Mar 26, 2014Explorer III
uintafly wrote:
I ended up taking care of everything last night. Had to add 2 washers and drop 2 holes. I also was running almost 2 inches tongue high, so I also dropped down an inch on the shank. Now I am running a little tongue low, which is fine by me. I was able to get the bars parallel and return the front wheels to the same height as before. Once you read through the manual the Equalizer is surprisingly easy to make adjustments on. Thanks again for the help.
I think you're good to go if your wheelwell measurements are in spec, and your bars are parallel or close to it. The trailer slightly nose down is fine IMO.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
