westend
Feb 01, 2018Explorer
If you can use the wind power not attached to the RV, that will be a better experience. Less noise and vibration into the RV, Or mount it on the ladder, you might like the soothing vibration?:@
I have a 7' stainless steel prop mounted into my DIY shaft bearing bracket. Generator is attached to shaft. I deploy it with one inch pipe and guy wires. Currently, it is a ***** to bring down and up but I have the steel in hand for a new bottom hinge that will greatly aid set up.
Good luck if you add wind power. I'm betting you won't harvest a lot of power but it's educational. For the casual RV'er, installing additional solar would probably net more power, IMO.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
