Terryallan wrote:
As mentioned the handle is not the adjustment. The bolt under it is the adjustment. Leave it alone. Unless the pads get really worn. Then you turn / tighten them 1/4 round at a time. 1/4 round is a lot more than you think.
I agree, thousands of miles on sway bars and I've never touched the adjustment nut for tension. Just tighten the handle down to bottom out the threads and then back off a bit to make sure the on off handle is pointed back towards the trailer and not towards the ground.
Thanks!
Jeremiah
