PSMike's avatar
PSMike
Advisable to stay hooked up on overnight stops
We have a big trip planned this summer and will be overnighting qit a few single nights on the journey. To get things going each morning I want to try to limit how much time I spend getting ready for the road.
Question: it is OK to stay hooked up to the hitch (Reese) or should I all together unhook to releive stresses on the trailer hitch and truck.
My assumption is it might be best to unhook (not remove) the sway bars and chains as these are under pressure, along with jacking up to the trailer to releive stress on the truck, but otherwise I can keep the trailer on the hitch ball, chains, electrical, emerg brake and essentially 80% hooked up.
What do you think?
  • When overnighting for a few hours of sleep we do as little as possible to our set-up if we are somewhat level. We usually spend a bit of $$$ at the establishment (fuel, groceries, breakfast etc.) but our primary intention is just getting up early and hitting the road. I always disconnect the 7 pin umbilical ensuring TV battery stays charged.
  • We had a tr and now have a 5th wheel and do it if we are just overnighting. Put rear stabilizers down and front until the weight is off the hitch. Plug it in and put out the slide.
  • IF you find yourself in a pretty level site, and don't have to run the hitch jack up much to get level, go for it. But if you find yourself picking the rear wheels up off the ground to get level, don't do that.
    You gotta keep your rig level overnight to prevent damage to your fridge, as well as to make it comfortable for sleeping. Nothing quite like the thrill of waking up in the middle of the night 'cause you slid right off the end of the bed. And that much slope will kill the fridge in a matter of weeks to days.
  • RoyB's avatar
    RoyB
    Explorer II
    I would definitely unhook the trailer 7-way power connector. I would not want to drain the truck start battery down for any reason.
    In my case my F150 ford truck will disconnect power to the 7-way connector after a short time-out after the ignition key has been turned off but alot of other trucks do not have this feature.
    Other than that I don't see any benefit one way or the other... Personal preference I suppose.
    Roy Ken
  • I have done it many times without any problem. I did put the "foot" down on the trailer to lift a little weight off the hitch and tow vehicle springs sometimes.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
