- RJCorazzaExplorerX2 for the voltage boosters. I have a Hughes Autoformer and love it. At 109v the Hughes will boost the voltage to about 120v.
- Big_KatunaExplorer IIAnd it's probably lower at the AC.
- Old-BiscuitExplorer IIIWhat is the AC voltage prior to starting A/C Unit?
How long running A/C Unit before you see the drop in voltage to 109V AC? - TechWriterExplorer
bob@29154 wrote:
I have "save a watt" gismo I use in my rv. When starting up air voltage drop is minimal but after running voltage drop as low as 109 volts. Plugged into 30 amp service
It's Summertime and the voltage is a'sagging.
My guess is that your park's voltage is dipping because of all the ACs being used by everyone in the park.
Get one of these autoformers/voltage regulators to "boost" the voltage from the power pedestal:
- PowerMaster
- Hughes
- Surge Guard Voltage Regulator - Jack_Diane_FreeExplorerYou could also switch water heater and fridge to gas to take some load off. Works for us.
- ScottGNomadStart checking the connections at cord and breaker for heat. Excess heat means a bad connection.
- Mandalay_ParrExplorerMay be a sign of a bad electrical connection somewhere. Heating up and causing further voltage drop.
- Sandia_ManExplorer IIIt's lower than I would like to see but 109 is still within 10%, although for compressor longevity you don't want to see AC voltages much lower than that.
- pianotunaNomad IIIHi,
It would be best to continue to monitor the voltage. If it drops below 108 when other devices are on it may be best to not use them. - Jack_Diane_FreeExplorer109 is not a problem.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
