Golden_HVAC
Jan 19, 2015Explorer
PawPaw_n_Gram wrote:
A couple arrived to camp host at a park we were finishing up.
They had an Entegra 'All-Electric'. They had come in from Quartzsite. They said they were dry camping there for a week and ran the generator two hours on the third and sixth day. Others wise there solar panels and normal boondocking electrical conservation was sufficient for them.
As I've said before - I'm expecting 'All Electric' fifth wheels will hit the marked within a couple years.
Somehow I don't think I would ever see a all electric fifth wheel, with the expensive diesel fired hydro hot heating system, diesel generator that is twice the cost and weight of a Onan 5,500 watt LP generator, and 10 KW of battery storage.
my 4 golf cart batteries store about 440 amp hours at 12 volts, or roughly 5 KW. It is 67 pounds per battery, or 268 pounds! Why carry around another 250 - 300 pounds of batteries? Why carry around a 250 pound Aquahot boiler and a hot water distribution system that can not be powered by the engine while driving down the road?
It makes sense to have a propane powered refrigerator, furnace, water heater. They are reasonable light weight appliances, and do not consume a lot of battery power.
Sure you can power things with solar power. I have had a 90 watt solar system since 1994. I added a 75 watt panel ($375 back then) in 97 and pair of 120 watt panels ($429 each) in 1999. Now it is so much less expensive, and installing a 500 - 800 watt solar system is easy to do.
Running the refrigerator on electric is very simple, and I expect the trend to change over to electric refrigerators to continue.
Running the heater on all electric is not so easy, as they require tremendous amount of power to heat a RV in 10F weather to a comfortable level, without burning propane or diesel fuel. Because most RV manufactures do not install diesel fuel tanks in a fifth wheel, I can not see them suddenly installing a diesel fuel system, diesel heater or boiler, and other diesel systems to replace the common propane systems.
A diesel furnace and Aqua hot heating system require yearly tune ups, cleaning of the burner, and other things, like fuel filter changes.
Propane burns much cleaner, does not require yearly maintenance, and no filter changes. Only about every 20 years, you should change the propane pressure regulator. This is only because the internal seals can start to leak or pass through a in-correct pressure, and should be changed. Not to say that a 1960's propane regulator is not perfectly safe, I am sure that many 1960's regulators are still in use, some 50 years later. But they should be replaced at around 15- 20 years old.
I have a 1997 motorhome, and nothing has been done to the propane water heater or furnace except clean out the water side by draining the water heater yearly.
Good luck!
Fred.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 18, 2026
